1 members (Red Rum), 5,343 guests, and 1,645 robots.
Hi All I'm new to this hobby and I've only got basic mechanical skills with lawn mowers. It's a great hobby from what I can see. What would be a good 1st project to start that's not too hard but where I could learn some stuff? Would it be trying to find a dead mower on a hard rubbish collection and see if I could get it started? Thanks Ted
Hello Ted and welcome,
Sounds like a plan. What mowers have you used before? I would suggest grabbing an old Victa 2 stroke and seeing if you can make her run, but I don't know whether you have used a 2 stroke before? I am a newbie as well to this, and apart from some light work on my own gear, I am in the process of acquiring my own first 'project' which I have to pick up from an ebay seller. But since I have previous experience and enthusiasm for the Victas, it was an easy choice for me.
The only problem with picking up a dead mower, as I see it, is if it has some issue like a ruined bore, or some other problem that would require specialist tools and experience to get anywhere with. It could lead to frustration, unless you just want to open it up and see how everything fits together, which isn't a bad idea in a way.
Good advice. As per other post. I got the Victa commando in my avatar photo she it supposedly didn't run but I just changed the fuel and spark plug and it started 3rd pull It had a note saying it didn't run stuck on it but I reckon someone had just out straight fuel Ill let you all know what I get up to Thanks Sapper
Hi Ted, you only get about 10 mins out of these motors if they are straight fueled, then it is a scrap bin job.
Ok
looks like you have caught the bug Ted12 . there is a wealth of info here. and plenty of us to help .👍
Hi Guys What do you think about the green Victa mower in the photo as a first proper project ? Guy is only asking $25, he said it stopped working some years ago and has been sitting in the shed. Worst thing is I can't get it going and I just end up taking apart the carby and engine and learning a bit. What do you think?
Perfect for a first project. My first Victa was a 1990 Standard 2 (identical to this but grey - actually might have been 1 below this green one as mine has the more basic wheels) - I paid $15 for it with catcher
I see a muffler rust hole at the front (probably patchable, but a very clean deck - no rear left rust near the handle mount.
All round looks very reasonable - rip the muffler off and have a look for piston scoring before having a go at repairing - wouldn't suggest this before sale as they can be a PITA to get back on
At the very least, its good for a play around with the carby - the starter alone is worth $25 online
Hard to check for compression without isolating the decomp valve, you could just try to compare the degree of wooshing noise with your keystart commando - that being said a straight fueled engine still gives a decent woosh sound from the decomp, so no easy way. I would suggest removing the spark plug and checking for speckles of aluminium transfer - a sure sign of engine damage.
I would snap it up Ted if it is reasonably local. Offer him a redback for taking it off his hands. If nothing else it will be good to play around with and looks like it has some usable common parts that could be used on other projects.
Be careful Ted, I only offer $10 for a non running Victa with a catcher, $5 without, as it is not running you can never tell if it has been straight fueled and I always point this out to the seller. If you ever see a plug that is a light brownish colour you can 90% guarantee it has been straight fueled
Thanks for the advice Norm
I secured the mower above for $20 yesterday late evening. Seems really solid to me, wheels and catcher good and surprisingly little paint missing. I really like the green, cool color. The cap over the air filter is missing and filter looks like its ruined. I just had a quick look this morning before work in the dark. Took the plug out and looks okay from my layman eyes. I checked and also the plug is getting a spark. The tap from the fuel tank definitely working but when I pushed the fuel primer bulb didn't hear the whooshing sound of fuel. Got a feeling it could be a carby problem. I'm away this weekend but can't wait to get in to troubleshooting it next week. :yay:
wce Offline
Hi Ted12 You don't hear any sound when you push the primer bulb so I wouldn't be worried about that. If you have spark, compression and fresh fuel it will run. If it doesn't then the diagnosis begins. Don't be tempted to keep pushing the primer as they flood easily. If the air filter housing cap is missing it is not a problem if it has been stored under cover but make sure the air intake is clear. If they are left outside rain or sprinkler water will run down the air snorkel into the engine which is not ideal. A word of warning about beginning to play with mowers, it's very similar to the coronavirus ( in your case Victavirus ) and once it takes hold is very difficult to contain. Start clearing out the shed now or start plans to get a larger one. Have fun wce
Thanks WCE Unfortunately I've only got a small shed so will have to keep it under control :) I'll buy a new spark plug next week and change the fuel and give a try. Previous spark plug was in the port a bit sloppy so the previous owner must have played around with it but I can see its old so hasn't replaced it. I reckon a bit of rain could have got down the air filter snorkel thing on the push bars as it might have been stored outside in the rain and the cover is missing off the air filter snorkel thing so some water could have drained down. Do you know where you can buy one of these covers from ? I've seen the air filter on ebay etc but not the cover. Yes when you put your hand over the spark plug port with the plug removed it makes a nice whooshing breeze when you pull the starter. Do you bother to use a compression tester ? If so what one do you have ? Do you really need it ? Thanks
Hey Ted, You should be able to find another Victa soon enough that has a cover. Or try contacting some of the online stores and see if they have one. Quick tip; Don't start looking to see if any more Victas are for sale or around. You will start finding multiple bargains, and maybe just one more mower could be squeezed in...I am desperately trying to fight off the virus at the moment.
Funny you guys mention keep mentioning coronavirus , someone will read this forum in 10 years time and won't know what you are talking about
wce Offline
Hi Ted12 Only spend the bare minimum to get it going then decide what you are going to do with it. If it looks like being expensive to get it going keep it for spares and move onto the next one, they aren't worth much even in good running condition ( unless you can convince someone it's an SB 45 ) Don't worry about the filter cap til you have it going and your happy with it, if the spark plug has a decent spark don't replace it. Not sure what you mean by sloppy in the port, was it finger tight or does the thread in the head look damaged, the plugs don't need a lot of tension when tightening, its Alloy. They have a decompression valve so you wont feel full compression when you pull it over. If you take the valve off and fit the spark plug into the hole then put your finger over the spark plug hole there should be a heap of compression when you wind it over. The head bolt in the picture doesn't look right which indicates someone has had a go at something. Cheers wce
That is a funky colour alright. A set of yellow wheel covers will set that off, as I used to see one in that combination in the former mowed shop down the street and it always caught my eye -then again any mower catches my eye lol.
Plug doesn't look the best to me, I guess somebody cleaned it trying to get it running. Even if you have spark on the plug don't trust it try a couple of plugs
Hi NormK, what colour should it ideally be? I look for any sign of life and run with that. Has worked 99%'of the time.
Hi MF, if it is black that shows it hasn't been straight fueled, brown is a dead give away that it probably has been straight fueled As soon as you pull a brown plug I get very nervous
NK, I was referring to blue spark, white spark or yellow spark and what that indicates. The colour of the spark plug itself is helpful. Straight fueling is becoming more common so this info gives a quick indication whether to pull the exhaust off and examine further. Yesterday I pulled out a mower after a long time and there was thick fuel the bottom so I added a tiny bit of petrol before adding a fair quantity of 2 stroke mix. I'm not being foolhardy am I, as it could cause it to become 30:1.
Sapper, that plug looks distinctly Chinese - Torch, LD or Carlton.
Keep the plug (as you could always end up with a dud new one), run down to repco and get a NGK BM6a - will cost $5 if you are a autoclub member as 20% off
First thing I do (after plug) is pull the muffler off - saves time and money that way. If its at the tip, I just pop the top clip with the 10mm/CJ8/flat blade scrench I keep in my pocket
If its scored, I put all parts together and walk off whistling. Also means anyone else will know what they are getting when they look.
MF, so long as its quality oil, it would be fine. I drain all mine after use - nothing is wasted that way - unless I kick the old 1l kero bottle over
G'day Tyler,
Could you tell us more about what that tool you carry is?
Hi Taylor, btw you are spot on, the brand is Carlton on the plug, I'd never heard of it.
Just a question guys, one of the screws that holds on the engine cowling / fuel tabk cover is all corroded and the the screw stripped. How would you guys get this scree out? would you just drill it out or use a screw extractor or something to get it out?
Hi Ted, This I assume is on the PT? They can be a problem and sometimes I can get them drilled out, sometimes I can't . A couple of times I have had to resort to hacking the cowl up just leaving a bit of plastic around the screw and then getting in with the grinder and cutting the screw off flush with the top of the starter housing, then drill and re-tap the thread. As I have plenty of cowls it is not a problem to me. I would be a bit reluctant if it was one of the later cowls but in the end you have to get it off somehow
Hi Ted,
Is there any possibility of using something to cut a notch for a flathead screwdriver? If not, you can get sets of bits for removing these screws. I have a set I bought at aldi years ago that I have used with success a number of times. It is called, quite surprisingly, a 'damaged screw remover set'.
I think there are some of these at Bunnings too.
Yes on the PT, I was thinking about trying either the screw extractor Sapper is talking about or an impact screw driver, thanks It's a bit of a bad design in the sense that it's sits done low below the top of the cowling and the water collects and it has corridoded
I have tried soaking them in penetrene but never had much success once the steel screw corrodes in the aluminium it is an uphill battle trying to get them out
Moderated by  bigted, Bruce
Redseyred, avelingandy, Cdlmhunt5, BobsYourUncle, shjump
18,152 Registered Users
Members18,152
