2 members (Lawn_King, Dandare), 1,196 guests, and 252 robots.
by Ghost - 25/10/25 07:11 AM
Victa 24 engine pulleys
by NormK - 19/10/25 08:49 PM
Re rotomo crankshaft.
Rotomo crank shaft
by NormK - 25/10/25 09:57 AM
by NormK - 22/10/25 09:06 PM
The Rover Pro-Cut Chronicles
by DFB - 19/10/25 09:36 PM
Rotomo crank shaft
one of those falcons for sale on gumnuts
https://www.gumtree.com.au/s-ad/west-ipswich/lawn-mowers/vintage-falcon-3-wheel-ride-on-mower/1176675165
I decided to take the deck off to fix it up properly. The blades are actually 18 inches long. So far I have pulled the brake assembly apart cleaned it up and now moves freely and works . The clutch mechanism needs the hole the linkage slots into welded to fill in were it’s been long gated due to wear . Also need a collar to fit over the bolt that engages the blades to stop it moving back and forwards hopefully that will stop the belt from falling off and some new blade spindles . What I cannot find is a diagram to find out how it’s suspended at the rear
Hi Dembones and all There is a 1979 8 HP Lawn L8218CR manual here http://www.stripmine.org/sears/layout/rtm.htm The deck looks a very similar setup to your Roper. That Falcon on gumtree says, Very sought after, Rare Collector’s item,but it's been for sale for nearly 8 months. Cheers Max.
Thank you Max . That makes life easier ðŸ‘
Hello all. I was wondering if these posts should be moved to a section on roper ride on’s . Seeing as there’s been a lot ground covered here it might be useful for others . Just a suggestion as it’s helped me a great deal . Thanks again to all that have replied as their not a lot of information available to a novice like myself. Cheers
G'day Dembones
Yes, I agree.
I have moved your topic to a suited forum.
I have renamed your topic.
Clearly, these posts belong in a more suited forum.
I hope you agree with the move.
6 7 8 9 10 11 12
13 14 15 16 17 18 19
20 21 22 23 24 25 26
27 28 29 30 31
Joekob, Muntz, Dragos, fordy, Mikey.Menace
17,645 Registered Users
Topics13,011
Posts106,980
Members17,645
PHP: 8.3.26 Page Time: 0.024s Queries: 28 (0.020s) Memory: 0.6509 MB (Peak: 0.7037 MB) Data Comp: Zlib Server Time: 2025-10-29 09:46:11 UTC
