537
1,807
robots.
Admin ,
Global Mod ,
any help at all ? Using the machine the other day when the Blower wheel came off , everything stopped. After collecting up the attaching nut and washers and putting them back on. The machine will not start again. Inspected the machine all seems OK . So whats the problem? Regards All At 97
after further inspection I thick the problem could be in the ignition .Any way of checking this module? Regards All At 97
Check the flywheel key it usually strips when this happens
Sometimes stuff just happens (usually to me)
There is not a flywheel key on this model.
ah yeh there is its part of the flywheel
The is a photo of the Flywheel in the forum Photo's.
Is that the key highlighted that you are referring to?
Regards
All At 97
yep thats where the key goes
Yes found the key but it's disappeared into thin air. Thanks for you remote diagnosis 100% correct. Next question where do I get these keys?
Problem on further inspection of the flywheel the keys are only formed by the aluminum being compressed and raised to form the key. cheap production process. thus I think i need a new/secondhand flywheel. any ideas where to get?
Chainsaw Addict
Is your flywheel the same as this one?
All at 97,
A new flywheel is expensive I would be trying to get a second hand one and when putting it on make sure the nut is done up tight otherwise you will do another key.
I have posted some images of the faulty flywheel in the photo forum . If any body can help with a 2nd hand on it will gratefully be appreciated. Regards All At 97
Chainsaw Addict
All At 97, If you cant get another flywheel it might be worth trying "loctite" on the shaft & the flywheel nut. It should hold ok. cheers gmax
Problem solved Removed a small amount of the old aluminum key so as to get good purchase when using small amount of
Selleys Knead it epoxy putty to replace the old key. Then just put the flywheel back on, Tight as possible. when putty set (couple of hours ) re assembled the machine, and fired it up,
WENT FIRST TIME.
Thanks all
Regards
All At 97
All at 97,
Let us know how long it last as I am sure that the members will be interested as they might try it themselves in the future.
Chainsaw Addict
Bruce, I would try that for sure, nothing to loose, being expected to buy a new flywheel just because the key shears off is a bit rich!! cheers gmax
Topics12,746
Posts106,765
Members18,064
Most Online40,124Apr 13th, 2026
