3 members (AMP, Ausmow55, MowingManiac), 1,902 guests, and 690 robots.
Bushranger cylinder mower
Acrher Chainsaw Chain
by AVB - 21/01/26 09:00 AM
Model number - where is it?
by Koii - 12/01/26 12:06 PM
Sanli Redback Ret Spring
by NormK - 22/01/26 02:05 PM
by NormK - 21/01/26 09:55 PM
Rover Thoroughbred Model 85
#101454 23/10/19 11:51 AM
Hi Guys,
I have bought an old Rover Colt 8 Model No. 7347.
It has been re powered with an 11.5 Hp Briggs and Straton.
It seems to travel far to fast.
The pulleys and gear box drive sprocket all look to be OK and original.
Any ideas would be appreciated
Phil
1 member likes this: Mike Bravo
Hi Phil,
Welcome here, seems like nobody with Colts are going to chip in with any suggestions. It would have required some drastic modification to be able to alter the speed on one of these. I assume this is just a single speed forward/reverse gear?
Hello Fliped61 and Norm
The Model 73 was the last of the colts - with Model 7313 (5hp), 7344 (8hp)
and the 7347 (8hp elec start?)
My best guess is that in converting the machine to an over-powered 11hp,
the primary pulley (on the 11hp engine) is too large.
If the travel speed is too high and the transmission sprockets look original,
the first check would be with the engine drive pulley, not the chain trans
after the gearbox output.
Hope this helps
Hi Jack,
Good call there, I'm just wondering if the pulley has been put on upside down, I assume it could be done, this would mean the cutter pulley would be driving the gearbox. This would mean that both belts must have been changed and I thought that would have raised the alarm bells as both belts would not be from the parts book
G'day Norm
Maybe ... the schematic list seems to say that is possible.
['5' is the engine pulley]
My best guess, though, is that an 11hp unit complete with its pulley
were swapped with the original unit.
An 11hp unit is not suited to the colts, and I suspect the little gearbox
unit will fail quickly.
Yes Normk it is
G'day Jack,
The pulley is the correct way up.
I suppose it would be difficult to get another engine pulley?
And if I could would it fit the 11.5 Hp engine?
Thanks for you're help Norm and Jack
Hello Flided61 and Norm
I thing the larger crank on the 11hp prevents a solution here.
I think a larger diameter input pulley to the gearbox is the best way forward (and reverse) laugh
That's my best guess.
Hi Jack,
The shafts are all the one size, one inch diameter and the rev range will be similar so there is something fundamentally wrong.
Phil,
Do not think about trying to find another pulley, you have to work out what is wrong. Are you sure the big end of the pulley is driving the cutter belt?
Hi Jack,
Yes the engine pulley is definitely correct with the large diameter driving the cutter
Ok so the only other thing that can be varied is the rear sprocket diameter, no chance somebody played with it for lawn mower racing?
Where can I get the pulley and sprocket sizes?
Hi Phil,
Sorry I have no idea I would email these people and see what they say.
https://www.ebay.com.au/itm/FOOTE-DRIVE-SPROCKET-FORWARD-REVERSE-GEARBOX-SPR1767/283653753842?
Thanks Norm
A few pictures may help, but there really isn't that much to these machines. How fast is too fast by you're impression? Most of these colts go sort of a brisk walking/jogging pace, to slow them was just to slip the belt like a clutch..
Just another thought, how fast is the engine revving?
nath #101539 29/10/19 09:02 AM
Thanks Nath,
The engine does seem to rev pretty hard
Is the governor working or has it just been cranked up to rev hard, if so it needs fixing to be able to come back to idle when stationary, then you can work out the rev increase you need for cutter speed and travel.
I used it today and noticed yes it does rev hard with the throttle at about 3/4 open.
If I cut the revs back the engine dies under load, and it wont run at a slow idle when stationary in nuetral
Well that is where your problem is , now it is a case of what is wrong with the carby and governor
I;ll get some photos of carby linkages ect
17,805 Registered Users
Topics13,058
Posts107,236
Members17,805
PHP: 8.3.28 Page Time: 0.095s Queries: 60 (0.084s) Memory: 0.7344 MB (Peak: 0.8589 MB) Data Comp: Zlib Server Time: 2026-01-23 00:47:07 UTC
