1 members (MowingManiac), 897 guests, and 238 robots.
Cone siezed on PTO Shaft
by ToryC - 12/11/25 02:18 PM
Kirby HK30 Governor oil leak
Tanaka TBC2251
Star Poducts cylinder mower
by Widget - 03/11/25 08:12 PM
by Magilla - 12/11/25 09:10 PM
Lower Crank Seal - Sprint 35
by AVB - 12/11/25 10:13 AM
Tanaka TBC2251
by NormK - 11/11/25 01:04 PM
GCV 160
by NormK - 11/11/25 08:22 AM
Gear Head Maintenance
Edit:
Disregard below.
I might not have wrapped my head around this.
Does a visual check of the valves (and an u derstanfing of where TDC is) not represent the camshaft timing??
In other words, with the valve cover off and spark plug out using the trusty screw driver method and spinning the flywheel to find TDC any discrepancy with the camshaft timing should also be evident....??
Or is there something else in the camshaft timing that can't be determined without gaining access to it?
Just don't want to rip the engine off the chassis and get in to the guts without understanding the requirement first.
Edit: Sorry Norm, just saw your response on the previous page
The valves and timing appear to be functioning as they should with both valves closed at TDC
Ok if all is as it should be there is no reason why it won't run unless it isn't getting fuel, nothing else left
Hi Lockstock
On TDC the mechanical compression release has one valve slightly open on TDC,
Never adjust Valve clearances on TDC when a Compression release is used.
I would usually disconnect the coil kill switch wire just so you know it's not intermittently earthing out.
I like to swap the coil just to rule that out as having a problem under load but if you don't have
a spare you wouldn't want to spend thirty dollars for nothing if it's not the problem.
https://www.outdoorking-forum.com.au/forum/ubbthreads.php?ubb=showflat&Number=59750&page=all
Thanks Max,
So if the valves aren't to be set at TDC where should they be set?
The engine doesn't have too much compression as it freely spins under the power of the starter mower....
Hi Lockstock
The service manual would explain the adjustment better , All I could find was the following, Valve clearance spec is .004" , and yes at top dead center of *compression stroke* , plus about 5 degrees of additional flywheel movement (piston moves down about 1/4" after top center) - Or, set each valve one at a time by turning engine until one valve opens fully, set clearance on the other valve, until both valves are set.
If you don't have the manual but know the clearance is .004 " then I would set each valve one at a time by turning the engine until one valve opens fully then set the clearance on the other valve.
Thanks Max,
Great flow charts too.
Currently got the bottom end apart and no obvious signs of damage. I'll be sure to set the valve clearances as per above.
Feel free to jump in with comments if you see anything glaringly obvious in the pictures
So after setting the cam timing again and reinstalling everything it eventually kicked over and idled very roughly for about 10 seconds.
I also set the valve clearances in the way Max suggested (with one valve open and the other fully closed.
It surged a few times then died and I'm sure it was running off aero starter rather than fuel from the carb.
Is it normal for the starter motor to cut out and then re-engage the flywheel when trying to turn the ignition on? It seemed as though it was making the engine cough when it was doing this....
G'day Lockstock
The starter pinion is on a lead screw so when the starter spins the pinion gear engages with the flywheel but when the motor
runs the flywheel is spinning quicker than the starter so this will disengage the starter pinion.
If the motor fires or runs while cranking then it is normal for the starter to disengage .
Sounds like the carby needs a good clean out .
Thanks Max,
I've pulled everything I can think of off and cleaned and reassembled. And finally, I was able to get this thing to run.... Very roughly.
It doesn't like to start with the choke closed and surges wildly but I still call it a win.
I may have damaged the carb main jet o ring of the washer for the main jet screw as it now leaks fuel but hopefully that's an easy fix for the future.
Time to get the carb tuned and see if this thing actually wants to cut.
Thanks to all those who gave input, much appreciated
gkov3, The Umpire, cornflakes, Kymmy, sahara
17,664 Registered Users
Topics13,019
Posts107,017
Members17,664
PHP: 8.3.26 Page Time: 0.021s Queries: 37 (0.015s) Memory: 0.6696 MB (Peak: 0.7383 MB) Data Comp: Zlib Server Time: 2025-11-12 17:56:52 UTC
